Post by LuapYllier on Jun 17, 2014 2:43:56 GMT
If you go into your profile, select "Edit Profile" and then pick the "Settings" tab you will now find two options for "Forum Themes". The default is "Red Rum Racing - Red" which is the current color scheme. There is now also a "Red Rum Racing - Black" available which may be more friendly for work or other locations.
Please tell me what other colors you might be interested in seeing.
Post by Deleted on Jun 17, 2014 3:09:58 GMT
That is awesome! Thanks Luap...I was missing the black!! By the way, I really like the red outline in the black setting too.
Post by coach_wargo on Jun 17, 2014 3:32:42 GMT
^^What he said^^
Post by refuso on Jun 17, 2014 11:25:10 GMT
Great stuff! I think Clio wanted a white one IIRC
Does it take long to make a theme? I guess it's quicker now you've had a play about so know what changes what?
Post by nittydon on Jun 17, 2014 11:46:21 GMT
Great Work Luap
Post by LuapYllier on Jun 17, 2014 11:49:18 GMT
It depends on what we ask for. For instance to do the black one with red accents was pretty easy. To do a white one should be easy as well but I am not sure how good it will look. To do something that does not go well with the red accents will take a bit longer but is feasible.
Post by CloudFuel on Jun 17, 2014 15:03:59 GMT
Good stuff. Thanks Luap!
Post by Deleted on Jun 17, 2014 15:07:57 GMT
great. im gona change it back to black asap
Post by LuapYllier on Jun 17, 2014 16:26:02 GMT
Just to be clear, the new black version is not the same as the old one. The backgrounds of the board and posts are black but the other improvemets will remain.
