Post by LuapYllier on May 5, 2014 10:29:42 GMT
Post by Deleted on May 5, 2014 11:54:09 GMT
Good stuff Luap  . If I were able to make similar wingsuit vids I have estimated there length to be at about 2 seconds each based on recent experience and far less entertaining than yours unless one is drawn to inept 200mph faceplanting videos.
Post by refuso on May 5, 2014 12:29:27 GMT
Nice. Particularly liked the tight squeeze one and the group stuff. Have you tried pressing the right stick in to look behind you while doing it?
Are you doing it in free roam? If you know someone that's usually up for gliding I'd say make a quick deathmatch. Just stick a load of parachutes and spawn points on top of Chiliad. Then you can kill yourself or put helicopters along the bottom to get back to the top
Wingsuit
May 5, 2014 13:12:00 GMT
via mobile
Post by LuapYllier on May 5, 2014 13:12:00 GMT
I was doing them in freeroam but yeah aDM might be a good idea.
To do the flight tracksta you jump off and dont touch anything until he starts the freefall animation. Then just edge the left stick forward very lightly to get forward momentum. Once you master the max distance then you can start playing with your angle to get close to obstacles. For me the hardest part was learning when to start with the stick. If you go too early or too hard you drop like a rock.
Really wish we had some spandex lol. Gonna do it with a helmet from now on...safety first!!
Wingsuit
May 5, 2014 13:14:26 GMT
via mobile
Post by LuapYllier on May 5, 2014 13:14:26 GMT
OMG...you just gave me a great idea...if I put pickups or props or such in certain spots they can be targets...or stunts.
Wingsuit
May 5, 2014 19:30:00 GMT
via mobile
Post by LuapYllier on May 5, 2014 19:30:00 GMT
I have been thinking about this all day and I think I have a doozy. It will be a capture. The parachutes will be targets placed strategically on ridgelines or other spots that you can wingsuit to so that you jump with no chute...pick up the chute on the way down by passing through it and then continue on down the mountain. The packages will be loaded on choppers at the bottom of the hill with the capture and spawn points at the top of the hill.
Post by refuso on May 7, 2014 10:15:20 GMT
Jumping onto a parachute and gliding away before you hit the rocks sounds hard. Have you done it?
I like the props for targets idea. You could stack some props and delete 1 in the middle for people to glide through. On my DM I put all my props at the top: float pile stair cases for higher places to jump, float pile stair case to get on to the cable car cabin easier, ramps off the mountain with some bikes up there too so you can ride off the mountain then jump off the bike and a floating platform about 40 cabins high
Wingsuit
May 7, 2014 14:28:48 GMT
via mobile
Post by LuapYllier on May 7, 2014 14:28:48 GMT
That whole concept failed as I could not get wingsuit flight without the parachute already in possession.
I left it pretty natural for now with no props but may add some stuff later. I tried to prop one area on a ridge as a target but could not get anything large enough to stack to place on the slope. It is still usefull for making vids though in the future...just kinda sad it requires minimum 2 people. I cant just go at it whenever I feel like it.
Post by refuso on May 7, 2014 23:49:07 GMT
Yeah the 2 people minimum sucks. If I want to go gliding and no one else does I just load it up in creator and 'Test' it. I guess it works the same for capture. Just remember to turn invincibility on/off as needed and it's not too bad
Post by Davexen on May 15, 2014 15:55:10 GMT
You can play the gliding playlist by yourself though, if you want to practice or just have fun gliding around.
