Post by worthsclio on Mar 17, 2014 18:05:47 GMT
Hi Guys Thanks for stopping by the brand new Grape Speed Circuit, Here you will find a race for everyone, 5 different circuits in one "arena" Be it technical, flat to the floor, a mixture or a good old rally, i'm sure you'll find a circuit to suit you. Unfortunately due to bad weather only two of these circuits are open today, with work due to be completed on the other 3 circuits any day now. The first of our new circuits is the Grape Speed GP, this is a fast flowing track designed for sports cars only. With average lap times of 1 minute I recommend 3 laps minimum, The Second of our circuits is for the super cars Grape Speed Super GT, here you find the first half of the lap is Grape Speed GP and the second half is Grape Speed International which is yet to be finished.
Post by Cuz05 on Mar 28, 2014 20:18:43 GMT
Ok man. This is going far more from the map than from memory and looks a bit OTT, so if you feel some of the ones I've marked should stay then definitely keep em because it didn't seem like as many as this. The 2 that definitely need to go are 23 and 49, I'd put 53 high up on the list too. The rest, do what you think is best. If you wanna leave em in then do so, they shouldn't cause any problems as they are I just thought this looked neater. Visibilty is the key. Red for out, white for in.
Post by worthsclio on Mar 31, 2014 10:16:48 GMT
Cheers Cuz I've amended to your suggestions and it runs miles better thanks
Post by Cuz05 on Mar 31, 2014 11:50:48 GMT
Always nice when my suggestions turn out not to be a pile of tosh Happy to help.
Post by Cuz05 on Apr 16, 2014 5:30:20 GMT
Mayhem at the Docks, my man. Couple of CPs that can just be whipped out and thrown away, 10 and 12. Couple that could possibly use bringing closer to the apex, although I didn't push my luck by cutting as close as possible to the inside line, if they pick you up when you do then they're fine but it looked a big gap, 1, 8 and maybe 6. Then it's perfect. I like the simplicity of this race, I like the little jump and crossover and I like how it's all enclosed, nice one Ok, I just noticed the other thread where you originally shared this....
Post by worthsclio on Apr 16, 2014 7:18:47 GMT
Cheers Cuz for the feedback much appreciated When I was re editing, i made the mistake of deleting some checkpoints, only to discover that this race is on the limit of 0.42 miles, and I have had to place the CP's to get the length to increase it was stuck on 0.41 for ages, I shall have another look and rework though, it my just need a little extension, which would then make it easier to edit. I believe the CP's will pick you up from when I tested it, Glad you enjoyed it, As I said this was the first one I created, and I'd like to more like this but prop limits are a pain
Post by Cuz05 on Apr 16, 2014 9:19:55 GMT
Well if you need those extra CPs for length then leave em in, they're not a technical problem just one of neatness. I personally wouldn't want to risk getting embroiled in an edit for the sake of it and losing the flow of the course.
Post by worthsclio on Apr 16, 2014 10:20:38 GMT
I don't mind editing any of my races to make them neater easier to use,
I did think the same thing about the last couple of cp's but i've just tried to edit them and there is nothing I can do, I can't move a single CP it's that tight.
