Post by Deleted on Jan 22, 2014 4:31:54 GMT
Test your mettle with intricate turns, you'll have to play your cards well to get in front.
Post by Deleted on Jan 22, 2014 5:28:44 GMT
Warning: Not for the faint of heart. Small stretching sections but the make or break parts are tight alleys, some only wide enough for a single car at a time. Pick your chances wisely. By the way, watch out for the bus....
Post by Deleted on Jan 22, 2014 6:30:35 GMT
Long Stretches of High-way. You'd best hope you aren't left behind or it could be impossible to catch up.
Post by Deleted on Jan 22, 2014 7:01:52 GMT
I went easy on you with this version. Maybe eventually there will be a hard version full of twists and turns to really test you.
Post by Deleted on Jan 22, 2014 23:28:08 GMT
Boulevard Of VWood Dreams
A few tight turns and looping sections to test your skill. If you fall behind you might just be sharing a road with the lead, watch out!
Post by Deleted on Jan 23, 2014 1:34:31 GMT
Can be a bit annoying if you aren't careful, wouldn't want to be flying off the mountain or spinning out into the river. The things you do for a tasty meal. Stick with off-road vehicles unless you think you're too good for normal.
