Post by Mackenizie on Mar 2, 2016 23:43:46 GMT
Wait is this the one we ran last Nighthawks that had fire hydrants at every corner? If so, my car has never been cleaner. If your car isn't dirty than you're not really racing.
Post by coach_wargo on Mar 3, 2016 14:16:24 GMT
Wait is this the one we ran last Nighthawks that had fire hydrants at every corner? If so, my car has never been cleaner. No, the one from Nighthawks had no props, which may be why we hit every fire hydrant in Paleto Bay.
Post by jaystonepk on Mar 3, 2016 18:51:30 GMT
Wait is this the one we ran last Nighthawks that had fire hydrants at every corner? If so, my car has never been cleaner. If your car isn't dirty than you're not really racing. My car is always dirty. But it's usually littered with paint from rubbing others cars, small pebbles from ramming into concrete walls or bits of rubber after grinding across a tire stack.
Post by coach_wargo on Mar 17, 2016 21:10:19 GMT
Maximum Flash - rsg.ms/ceadb06I know a number of you guys raced it last week. Any feedback or suggestions?
Post by kidovey on Mar 18, 2016 12:22:49 GMT
Maximum Flash - rsg.ms/ceadb06I know a number of you guys raced it last week. Any feedback or suggestions?Nice track! I found those grey-ish wooden barriers a bit tricky to see in the sun against a grey concrete pavement etc but other than that I can't think of anything. Good stuff!
Post by coach_wargo on Apr 18, 2016 17:03:07 GMT
Who played my new track I See U? I was surprised to see it had 15 plays, so I assume it was a group from this crew, lol. Any feedback would be great.
Post by Cuz05 on Apr 19, 2016 20:56:09 GMT
We ran it last night Coach, but that was after your post... Don't know where those 15 came from... Fans presumably. 1st off, it's a good route, we enjoyed it. There were a couple CP points raised, nothing serious- none were missed AFAIK- and placement is fine. I didn't raise either so this is a bit of a guess from memory and not something I'd read much into, coming from me. One was, I think, 10 and 11 could be 1 CP rather than 2. Not sure about that one tbh, I might've used 2 there myself at some point. The other... really scraping here.... Speed said there could be one more somewhere, possibly after the 1st turn, looking at the map, or maybe after 9.... Dunno My own point would be the propping. Not many like fences it seems. Personally, I don't mind the unpainted ones, I use em myself in places where I need a thin barrier and maximum coverage (and yeah, they're not universally popular). The blue ones I find hideous. Particularly, I think they look kinda ugly together. If it were me propping the track, I would A) use sunken containers where possible, B) use only unpainted barriers where necessary (or only blue- bleurgh) and C) this is the main one, flip em upside down so you can reduce the height of them by half. It's so easy to do that now, just tick the box and rotate em, then lift em to the desired height. Can be finickety to align nicely but ofc, once you've done it with one, the next you put down will already be rotated and just needs a fiddle. Main advantage of this, especially given the idea behind the track, is that you can see over them much better, so I can see U on other parts of the track much more readily. There was one, maybe two turns where I thought the height of the barrier obscured the turn I was about to take a little more than I like as well. Depending on prop spread, a couple of the lane closures could be a teensy bit less sharp or possibly more illuminated or something. Especially if you sink unpainted barriers. So anyway. All pretty much aesthetic stuff from me, no complaints.
Post by SPEEDSTER0595 on Apr 20, 2016 13:59:11 GMT
Right, after CP9, infront of tinsel towers, one could go there. CP 9 tells me to make a hard left(three arrows), i know better, just a tad bit confusing, mainly aesthetics.
Post by coach_wargo on Mar 7, 2017 19:25:16 GMT
Post by kidovey on Mar 10, 2017 13:54:38 GMT
unless its changed since I raced it a coupla weeks ago, I still say its a nice cool track. the banked corner is a good build too. You had some bad feedback?
Post by coach_wargo on Mar 11, 2017 18:20:27 GMT
unless its changed since I raced it a coupla weeks ago, I still say its a nice cool track. the banked corner is a good build too. You had some bad feedback? Yeah, I wanted a second opinion. The feedback complained about the medians, but I think they were just driving poorly. They needed to pick a lane, not try to cross over the medians in the turns. Thanks.
