Post by LuapYllier on Jan 16, 2014 21:12:49 GMT
Do you get to keep the weapons you pick up in a Deathmatch? Or better said...Is there a setting for a deathmatch that allows you to keep your pickups?
I ask because if you can than I am going to make one specifically for rearming. Do it right at my apartment so I can host it and transport home rearmed any time.
Post by nittydon on Jan 17, 2014 13:43:39 GMT
It works like this for R* created DM's and Survivals, haven't tested on created but as long as you have the weapon set up correctly I can not see why not ? although surely this is a cheap way to re-arm and R* don't like us having cheap ways so maybe not ? I think you will need to test and let me know the results
Post by Deleted on Jan 17, 2014 14:02:02 GMT
I thought you kept the weapons you picked up until you log off. Not sure how it works for deathmatches. I know it should work for Survivals.
Post by LuapYllier on Jan 17, 2014 15:04:00 GMT
I know that is true for stuff you havent unlocked...just changing sessions can remove.them...but if i already own them im wondering if you can just pick up and keep ammo...gonna try it this weekend.
Post by Deleted on Jan 17, 2014 19:03:02 GMT
I have had my Ammo maxed for so long I do not know if picking weapons up will refill ammo but I believe it works in the way you are referring too.
Post by Cuz05 on Jan 17, 2014 19:18:58 GMT
Fill all ammo is about 160k for me normally. I'm paranoid about clicking it. No idea how it can be so high....
Post by Deleted on Jan 17, 2014 19:56:14 GMT
I maxed out my ammo awhile ago so now I just going into ammo-nation and doing a couple $400-1200 every once in awhile.
