Post by LuapYllier on Jan 9, 2014 14:07:56 GMT
Im sure we all know that while in the air the right stick up and down will raise or lower your front end, moving it right and left will roll the vehicle like a football spiral.
What you might not know is if you push left or right while holding A (emergecy brake) will SPIN the car like a top.
Similarly when in a boat holding the A button for the entire race does not slow you down but will allow you to make considerably sharper turns. That plus pulling back on the stick will give you maximum speed and handling.
Post by Deleted on Jan 9, 2014 17:45:59 GMT
Maybe the reason why I never found this out is because my right thumb is always on the stick and not the buttons. I wonder if this is just a button function or is it an e-brake function? You can also use the Right Shoulder button to activate the e-brake is the reason why I am asking. Someone might need to try this out.
Post by Mo-seph on Jan 10, 2014 11:51:07 GMT
Yea ground you can, I tested this alot last night and the LB/L1 ebrake does the same thing... 540 Sanchez flatspins are awesome
Definately think a backlink to the original thread on gtaf is deserved for this trick. New discoveries at this stage are rare, OP deserves some props for sharing this... Its changed my stunting alot
Post by LuapYllier on Jan 10, 2014 15:48:25 GMT
